Can anyone help with the prop zinc size so I don't have to get wet twice.
Thanks in advance.
CD30C prop zinc
Re: CD30C prop zinc
Sam, assuming you have a solid, non-feathering prop, a 1 inch prop shaft and you're in
salt water, this is probably what you need.
https://www.defender.com/product3.jsp?p ... &id=161398
Re: CD30C prop zinc
Almost positive you want a1in diameter, normal thickness donut. The one I get fit CC every year is a CMC03 from Defender. I think it may have a different number in their catalog but in my garage/ boat shop now, that's what's in the sticker on the one I have
Jeff
Jeff
Re: CD30C prop zinc
my 30 MKII uses size C bullet zinc. make sure you get a screw with loctite on it.
