V-Drive Needed
setsail
V-Drive Needed
Post by setsail »
Is there someone here that might have the Walter v-drive that would be the appropriate ratio to be paired with a Volvo Penta MD7A in a Cape Dory 30? (Model number/ gear ratio?) I'm currently in the Fort Drum/ Lake Ontario area and am considering a project but am having difficulty finding the boat's missing pieces. The boat has the engine and prop shaft but nothing in between. Any help will be appreciated. -Craig 207-907-9716
http://www.tadiesels.com/used/tran/tranw-1122.Re: V-Drive Ne
I have the Md7A with Walter's RV 10D. I'll verify those numbers today. I will be rebuilding mine soon because it sucks oil out of my engine crankcase,and I guess that means the seals on the transmission are bad. http://www.tadiesels.com/used/tran/tranw-1122.html
Re: V-Drive Needed
That's the one RV -10D with 2:1 ratio
Walters V-Drive.JPG (118.35 KiB) Viewed 278 times
