My battery charger is not charging either battery. Normally, there is a hum when it is on, but there is no hum.
I pulled the shore power panel, and found 120v across the "battery charger" circuit. So, that suggests that I have current from the dock to the panel.
I'm trying to narrow the suspects, but am not sure what components could be malfunctioning, and would like to consider others before concluding that I need a new battery charger.
Is it possible that my battery switch has failed? I understand that there is some kind of diode in the switch (because I was warned not to turn the dial when the alternator on the outboard was running). If something has failed in the battery switch, how could I test that? And, if the battery switch failed, would that prevent charging? [I have now learned that the diode is in the outboard alternator, not in the battery switch. It appears I would be well served replacing the battery switch with one with AFD, which seems to prevent burning out the alternator's diode.]
I'm not sure where the "galvanic current blocker" in the wiring system, or whether (1) it fails and (2) when it fails what the consequence is.
A lot of this wiring is original to the 1986 CD 26 (outboard engine), so I'm not sure what improvements there have been since then.
I would appreciate any suggestions. Thanks.
Darin
