Universal (preferably M-18) engine parts
samgoucher
Post by samgoucher »
Searching for reliable parts source for a Kubota block Universal M-18 raw water pump.
Sam Goucher
s/v To The Moon
Frenchy
Re: Universal (preferably M-18) engine parts
Post by Frenchy »
Jamestown Distributors has repair kits for Sherwoods. Here's a link:
https://www.jamestowndistributors.com/u ... ?pid=43825
Paul D.
Post by Paul D. »
You may not need to get it here but check this site at least for reference to the right part and part number..
https://www.marinedieselparts.com/store ... mp_m12.htm
Find out whether you have a Sherwood or Oberdorfer pump on your motor.
Capt Hook
Post by Capt Hook »
The raw water pump won’t be a Kubota part.
You may have to go to Westerbeke. That’s what I ended up doing.
Capt Hook
s/v Kumbaya
Cape Dory 31, Hull No. 73
New Orleans, LA
Check to make sure which manufacturer and model pump you have and then start shopping on the internet. The Oberdorfer pump on Raven was leaking, years ago. I considered rebuilding and then decided to get a new one. I was pleasantly surprised to find that the new pup employed an O ring on the cover seal, instead of the, rather annoying, paper gasket. There are many suppliers of this pump and most will be cheaper than going through Universal. For any of the Universal parts that are not part of the marine conversion of the Kabota engine I go to my local Kabota tractor dealer and have found the parts to be about 1/3 the cost of buying them from Universal.
I am not sure if this is the pump you have but this is just one of the web sites I found in a quick search, Steve.
https://www.marinepartssource.com/rubb ... OEQAvD_BwE
Chrisa006
Post by Chrisa006 »
I know this is a horrible thing to say but look on catalinadirect.com. They have parts and complete Sherwood and Oberdorfer pumps.
Chris Anderheggen
CD25 "Windsong"
Catalina 30 "Kestrel"
Catalina 387 " Parrot Cay"
Credo quia absurdum
