Sta-Bil diesel fuel stabilizer
Capt Hook
Post by Capt Hook »
I've never used a diesel fuel stabilizer.
I tend not to burn much diesel in a season.
Is using a diesel fuel stabilizer something you guys typically do?
If I fill my 20 gallon tank that could literally last me years. Wondering if I should use a diesel fuel stabilizer.
Capt Hook
s/v Kumbaya
Cape Dory 31, Hull No. 73
New Orleans, LA
wsonntag
SURPRISE
Georgetown Maryland
Member Since 2005
Re: Sta-Bil diesel fuel stabilizer
Post by wsonntag »
I have never used it. However do use Bio-Bar JF every time I fill the tank for many years. For small tank diesel installations, the organic bloom of biota is the issue as the fuel sits, diesel's pretty stable otherwise doesn't turn to varnish like gasoline. Like you, I generally don't fill the tank but once a season as well as a fall top-off before shutting down for winter season. Again, all fill-ups include a dollop of Bio-Bar. A small bottle lasts many years. Cheers!
wsonntag wrote:I have never used it. However do use Bio-Bar JF every time I fill the tank for many years. For small tank diesel installations, the organic bloom of biota is the issue as the fuel sits, diesel's pretty stable otherwise doesn't turn to varnish like gasoline. Like you, I generally don't fill the tank but once a season as well as a fall top-off before shutting down for winter season. Again, all fill-ups include a dollop of Bio-Bar. A small bottle lasts many years. Cheers!
That’s what I’ve been using since the 70’s.
Capt Hook
Post by Capt Hook »
Thanks.
For the Bio Bar JF if an oz treats 80 gallons do you use an eye dropper to measure it out or just splash a litte in the tank?
Is the only downside to overdosing just the added expense?
Capt Hook
s/v Kumbaya
New Orleans, LA
Capt Hook wrote:Thanks.
The design of the container allows you to regulate the dose within reason. A little extra won’t hurt.
Paul D.
Post by Paul D. »
Every winter I've put about the directed amount of Sta-Bil for diesel into my freshly filled tank. The last few seasons we've used a full tank or two, but previously I would not even use a full tank all season long, only topping it off before winter storage.
Keeping a full tank and using Sta-Bil and occasionally some Seafoam Motor Treatment or Stanadyne has worked well in our northern environment. If I were down south I would ask around for what works locally as I think there would be more concern for bio growth etc.
Capt Hook
Post by Capt Hook »
Thanks all for your comments.
Capt Hook
s/v Kumbaya
New Orleans, LA
