Mast plate dimensions
Greetings,
Purchasing a CD 27 and while the mast is down I want to install a mast plate for future turning blocks. The boat is not close by and I need to know dimensions of mast step to order the mast plate. Garhaur has one that has dimension of 5.5 inches by 3.75 inches. I think that would fit.
Anyone have dimension of step or think that would fit? I could order the next size up but I think it might interfere with wiring going through the deck to starbord of mast.
Thanks, Walter
hull #35 new name pending
Thanks, Walter
Walter R Hobbs
CD 14 hull # 535, Grin
CD 27 Hull # 35 Horizon Song
Lincoln, RI
Lincoln, RI
Re: Mast plate dimensions
Walter, I think your boat's mast is a CD-4 cross section, 4"wide by 6" long outside dimensions. The mast step for that
section, shown on the Rig-Rite site, looks to be about the same size or slightly larger. It looks like the bolts holding it down
are on the inside, creating a smooth transition from the mast side walls to the outside of the step.
Hopefully, someone with a CD 27 can give you a more definitive answer. - Jean
Jean,
Thanks for the reply, I should have thought to check the rig-rite site.
Walter
Walter
Walter R Hobbs
Lincoln, RI
Lincoln, RI
Dwyer Mast also sells halyard plates if they are still in business. The DH 2890 fit my CD25D just right.
https://www.dwyermast.com/items.asp?cat ... zer+Plates
John
John
- Cathy Monaghan
If you can’t find a mast plate that’ll work with your boat’s set up, you can install a mast bail near the bottom of the mast instead.
You can just make out the two bails, one forward and one aft, at the base of Realization’s mast.
-Cathy
-Cathy
CDSOA Associate Member #265
Greenline 39 Electra
Rahway, NJ
Raritan Bay
Rahway, NJ
Raritan Bay
Hint to others: Right-click on Cathy's picture, then left-click on "view image"
If you "mouse" around on the picture, you should see a plus sign in a magnifying glass as the pointer.
Put that pointer near the where the mast meets the coach top and left-click to maximize the image.
(Disclaimer: All of the above is based on a windoze version of Firefox...)
Thanks people,
Kathy the boat looks beautiful. Thanks for the idea. Is that the Newport bridge in the back ground? Or some other suspension bridge closer to your home.
Walter
Walter
Walter R Hobbs
Lincoln, RI
Lincoln, RI
