Travel Lift Question
Having just had our CD27 Troika's hull painted with Awlgrip I am dreading her being launched in the yard's travel lift. Specifically, I am worried that the straps will harm the new paint. Other than asking the yard to hose down the straps or putting towels between the hull and the straps does anyone have any creative ideas to protect the hull? Thanks for all responses.
Re: Travel Lift Question
Two layers of heavy-duty(0.05?) visquene (sp?) between strap and hull used to work well.
Had the FR three times in the slings after I Awlgripped her. Talk to the yard. Good ones understand your worries and a good operator knows how to keep the straps off the paint...usually. Take pictures of your hull/topsides before they lift it. Inspect the straps for debris, sand, barnacle debris. Visquene as mentioned. I have also used indoor out door carpet taped to the straps when the yard did not show the care I wanted. Good luck.
At the very least, cut yourself four appropriately-sized pieces of clean corrugated paper (aka "cardboard") attach a loop of cordage on one end to recover them from the water with a boat pole once the boat floats, and then if necessary cover the pieces with clean cloth of some sort. Make sure you are on the scene when the boat goes into the Travelift, explain your concerns to the operators, and go from there. If your yard is either unwilling or unable to accommodate your concerns, then it' time to look for a new yard. Awlgrip is a bit tougher than most folks think, but it's your money and you will just have to be proactive to ensure things go well.jneely wrote:Having just had our CD27 Troika's hull painted with Awlgrip I am dreading her being launched in the yard's travel lift. Specifically, I am worried that the straps will harm the new paint. Other than asking the yard to hose down the straps or putting towels between the hull and the straps does anyone have any creative ideas to protect the hull? Thanks for all responses.
One final thought (and take this in the spirit it is meant): It's only a plastic boat that you are supposed to enjoy, so worry less and enjoy more.
JNeely:
I had the topsides of S/V Bali Ha'i professionally "Awlgriped" a couple of years ago at a boatyard. I also had the bottom sanded, prepped and painted with Sea Hawk Tropikote.
The yard installed large plastic wrapping around all four (4) of the lift straps to prevent rubbing/scraping. It worked well; no issues.
Make sure the yard also attaches two (2) horizontal lines securing the forward lift straps to the aft lift straps. Given the shape of our hulls (cut out forefront) you want to prevent the forward straps from slipping forward and having your Cape Dory do a nose dive onto the concrete yard.
Felice Anno Nuovo
![Exclamation :!:](./images/smilies/icon_exclaim.gif)
Felice Anno Nuovo
I second the idea of wrapping the straps with plastic stretch wrap. Most big box home improvement stores carry it, as does U Haul and on line stores such as the picture from an "Amazing" on line store. Also, our travel lift operator has some old 12 x 12 cockpit cushions that he places at the boot stripe and the toe rail just before tightening up the straps, to relieve pressure on the painted topsides.
![Image](https://images-na.ssl-images-amazon.com/images/I/71KUsIQi-eL._SL1500_.jpg)
Bill Goldsmith
Loonsong
Cape Dory 32 Hull #2
Loonsong
You really have to be careful about wrapping the lift straps in plastic ... they can lose their "grip" on the hull.
I would only do that where the straps contact the newly painted topsides if you are that worried about scuffing the finish. A little scuffing on the bottom coat hardly matters.
cheers
cheers
Fred Mueller
Jerezana
CD 27 Narragansett Bay
Jerezana
fmueller wrote:You really have to be careful about wrapping the lift straps in plastic ... they can lose their "grip" on the hull.
cheers
Good point and clarification. Protection is only needed where the straps would damage the topsides paint, not the entire set of straps. No need to wrap them where the only contact is bottom paint. My Travelift operator always ties the straps together fore 'n aft as well to prevent slippage on full keels and cutaway forefoot keels like most Cape Dorys have,
Bill Goldsmith
Loonsong
Loonsong
