For Sale: CD270, cutter rig!, in SwFL, (SOLD!!!!!)
GMJohnson
Post by GMJohnson »
Rare 1984 Cape Dory 270 in excellent condition.
Traditional Cape Dory quality and seaworthiness.
A big boat in a small package and ready to go cruising.
Hull # 7 of 21 built. USCG Documented vessel
Cutter Rigged with 2 Roller Furlings
LOA: 27’3” Beam: 9’5” Displacement: 8380lbs
Draft: 3'/7' with full keel & centerboard Mast Height: Approx.43’
Headroom: 6’1”
Tankage: Fuel: 15 Water: 46 Holding: 24
Accomodations: Walk-thru
Large Vee Berth forward with filler to form a double berth. Below the berth there are two drawers and cubbys for storage. Teak chart storage cabinet above vee berth .To the port is the head with standing headroom. Opposite the head, on the starboard side, there is a hanging locker and two additional drawers.
In the main salon, there is a teak table with flip-up leaves. Settees are on both sides of the cabin with custom cabinets behind. The port side cabinet is lined with cedar. There is more storage behind the back rest of the both settees. The galley is located on the starboard side where there is plenty of storage. There is a aft berth on the port side. The instrument panel is located behind the ladder. When the ladder is removed, there is easy access to the engine.
Galley/Salon:
●Brass Barometer & Clock
●2 Burner Hillerange Propane Stove with inside propane shut off
●Adler Barbour Refrigeration in large icebox (new compressor 1/2015)
●Teak Dish Cabinet
●Teak Wine Glass and Mug Holders
●3-Way Waste System 1)direct overboard (where legal) 2)24 gal holding tank with deck pump out fitting 3)overboard from holding tank using whale pump
●Three brass oil lamps
●Five Hella fans
Electronics:
●Autohelm ST2000
●Collision Avoidance Radar Detector (C.A.R.D)
●Standard Horizon Depth Finder
●Raymarine VHS Radio
●Standard Horizon CP190i color Chartplotter (new 4/2013)
●Two backup Garmin GPS units
Electrical:
●135 watt Kyocera Solar Panel, Blue Sky Monitor/Charge controller
●4 Deka Batteries with 440 amp bank (new 1/2016)
●20 Amp battery charger
●CD player/AM/FM Radio with speakers inside and in the cockpit
●Anchor light with photo cell
●30 amp shore power cable
●Guest Galvanic Isolator installed 1/2012
Mechanical & Engine Room:
●13 HP Westerbeke diesel engine
●Racor Fuel filter with gauge
●Electric Fuel Pump
●Bronze raw water strainer
●Bronze dripless stuffing box
●Built in pump to drain oil for easy oil changes
●Rule auto bilge pump
●Whale manual bilge pump
●Backup Rule auto bilge pump (1100 GPH) installed 2/2017
●High water bilge alarm
●Many spare parts including waterpump & alternator
●Bronze seacocks
●Vessel & engine manuals with complete maintenance & service records
Deck And Hull Equipment:
●Bronze ports
●Custom made companionway doors with windows
●Teak propane box & two tanks with manual remote on/off control
●Cockpit coaming benches
●#33 Bruce anchor
●Danforth secondary anchor
●Stainless steel anchor roller
●50’ of stainless steel chain and 200’ of ½” nylon rode
●Two Anderson #12 self-tailing winches
●Three Lewmar winches
●Winch handles
●Brass dorade vent
●Windex wind indicator
●Mast steps
●Heavy duty standing rig (2005) with sta-loc fittings
●Lightening suppressor on mast
●Stainless Steel swim ladder
●Spare Campbell Sailor prop
●New bottom paint (Pettit Trinidad 200, 2/2015)
Sails/Miscellaneous Equipment:
●Mack fully battened Mainsail with 2 reef points (new 3/2014)
●Mack Pack Mainsail cover/Lazy jacks (new 3/2014)
●Staysail
●110 Jib
●150 Light air sail
●Spinnaker/sock/ATN Tacker (new 1/2014)
●Whisker pole
●Tiller extension
●Dodger
●Cockpit awning with custom sunshades
●Custom hatch wind scoop and deflector
●Custom Sunbrella lee clothes
●Back rest cushions that ●2-person inflatable kayak/paddles
attach to life lines ●Charcoal grill
●Fishing rod holder ●2 Original paintings in salon
●American Flag off backstay
●Cable cutters
●Boat hook
●Bosun chair
●Fitted wood inserts to transform cockpit into a large sleeping area
Comments: Gettinair’s shoal draft allows you to get away from the crowded anchorages and explore. She is sitting pretty in a wet slip at Salty Sam's Marina, Fort Myers Beach, FL.
Asking Price: $25,000. Priced to sell and worth every penny
Contact: Glen Johnson (763) 360-8200 Call for more info and lots of current pics!
pete faga
Re: For Sale: CD270, cutter rig!, in SwFL, excellent conditi
Post by pete faga »
Sweet picture.
Any more pictures that the board could see?
GMJohnson
Re: For Sale: CD270, cutter rig!, in SwFL, SOLD!!
Post by GMJohnson »
pete faga
Post by pete faga »
Thanks for the added pictures
You have a beautiful boat for sale
