Oil/Trans Fluid Change Pump recommendation?
AMcC
Post by AMcC »
Anyone have an oil/trans fluid change pump recommendation for my Cape Dory 25D? (Yanmar 1GM and associated (Hurth?) trans). If anyone has a photo of the perfect engine compartment permanent mounting place, that would be helpful - or should I not mount it?
All suggestions/tales of experience appreciated.
-Alec
Northstar1014
Re: Oil/Trans Fluid Change Pump recommendation?
Post by Northstar1014 »
I have had this for many years and it has always worked perfectly. Not having a built-in version never bothered me. Plus you dont need to look for a waste oil container.
https://www.westmarine.com/buy/west-mar ... _-DY-_-PDP
Its a little small, but they make a bigger size.
My oil pan has a drain hose, but I still find this to be much faster for engine oil extraction.
S/V RESOLVED. 1983 CD-27. Westerbeke W-13.
bottomscraper
Post by bottomscraper »
I will UN-recommend the green horizontal ones. I had a "Marina-Pro" brand one that lasted all of one season. The pump part failed and the rebuild kit cost almost as much as the whole thing, I did like the small size.
I now have a "Tempo Oil Boy" that has worked well for about 8 years.
Rich Abato
Nordic Tug 34 Tanuki
Southern Maine
http://www.sailmahalo.com
AMcC
Post by AMcC »
Thanks. The West Marine 2.9 Qt pump looks perfect. I only have a Yanmar 1GM, so not much oil in there...
-Alec
Bob Ohler
Post by Bob Ohler »
I modified my pump to include a piece of straightened copper refrigeration tubing. It is perfect for getting to the bottom of the transmission case. I drain the crankcase oil and then go right to the transmission. It makes for a nice job.
Bob Ohler
Bob Ohler
CDSOA Member #188
CD30B, Hull # 335
sv Aloha Spirit
Keith
Post by Keith »
I have been using the 2.9 qt west Marine for 5 or 6 years and its perfect for the job.
Keith
