Jib halyard
Big E
Salem, MA
Jib halyard
Post by Big E »
The jib halyard in my CDI roller furler is toast. Does anyone have any suggestions on how to replace without unstepping the mast? Solstice is already on the mooring. Also, what length line should I get for a CD25? All replies appreciated. :D
bottomscraper
Re: Jib halyard
Post by bottomscraper »
I'm not really familiar with CDI furlers but manuals are available online, see link below. I believe they list the halyard size and length.
http://www.sailcdi.com/flexible-furlers
Rich Abato
Nordic Tug 34 Tanuki
Southern Maine
http://www.sailmahalo.com
Gary H
Re: Jib halyard
Post by Gary H »
You should buy a replacement halyard directly from CDI for the model/extrusion length on your boat. The halyard has a metal ferrule on it designed to slide inside the extrusion while the lower end of the halyard rides outside. You will need to use the existing halyard as a lead to pull the new halyard up from the bottom. Be careful not to pull an end up out of reach or you will be taking the mast down anyways.
CDI is a good company to deal with and will be helpful.
CDSOA Member 1389
