Located Bridgeport, CT
NOTICE: PRICED REDUCED $5,000.00 FOR SPRING TIME SALE. NOW OFFERED AT $19,900.00 DO NOT MISS OUT ON THIS OPPORTUNITY...TIMING IS EVERYTHING! From the design board of Carl Alberg the Cape Dory 30 Cutter offers a standard of seaworthiness and performance that lives up to her stunning appearance. Her second owner has maintained in proper yacht form and reluctantly is offering her for sale after 21 years of stewardship. For full details of maintenance history, see below.
For a personal description of this vessel or to schedule an appointment to get on board, please, contact the listing brorker, Bill Kolkmeyer, at 203-878-6373 x 1(O), 203-856-4669 (C) or by e-mail: bill@wjkyachts.com
MAINTENANCE-HISTORY
2016:
• Replace Vetus water muffler and exhaust hoses
• Replace exhaust riser
• Replace mixing elbow and fuel pump
2015:
• Replace electrical panel
• Replace ground cables
• Replace starter cable and two battery cables
• Replace starter
• NEW MAIN SAIL
2015:
• New Jib
• New Staysail
2013:
• Replace throttle cable
2012:
• Replace Bow Platform
• New starboard life-lines
• New Steel support for bow platform in chain locker
2011:
• Installed new Groco HF hand operated head
2009:
• New Main Sail Sail Cover
2008:
• Install new scupper hoses and clamps
• New water exhaust hose
2007:
• Installed Garmin 498 chartplotter
• Installed new depth sounder and transducer
2005:
• Installed new steaming deck light
2002:
• Sandblasted bootom paint off
• Applied West System epoxy and fairing, 10 mils Interlux barrier coat, Pettit unepoxy plus indicator coat, Interlux Micron bottom paint
• Install new tri-color light
2001:
• Installed new Schaefer 1100 roller furler to jib
1999:
• Replaced Galley and raw water seacocks
• Installed Schaefer 750 Roller furling for staysail and new inner forestay
• Replaced fuel tank including all lines and hoses
• Replaced hatch board with solid teak
1998:
• Replaced seacock in head
• Installed new Fairclough dodger w/cockpit extension
1997:
• Installed Navico Wheel Pilot 5000
• Installed Par Max 4 water pump for pressurized water
• New sink and faucet in galley
• New faucet in head
1996:
• Replaced engine shaft and cutless bearing
• Installed raw water strainer
• Installed Racor Fuel Filter
• Installed Atwood bilge pump and floater switch
