Question About TY Senior Cockpit / Lazerette Interface
MHBsailor
Post by MHBsailor »
Just went and looked at a TY Senior and I was wondering if the big opening between the cockpit and the outboard motor lazarette is normal (see photo below)? Also wondering if one took a following wave while running if some of it could come up the outboard motor well and into the cockpit? Thanks!
MHB Sailor
Chrisa006
Re: Question About TY Senior Cockpit / Lazerette Interface
Post by Chrisa006 »
On my CD25 there is a slide in board very similar to a companion way board that fills that space. It slips into a channel on either side.
Chris Anderheggen
CD25 "Windsong"
Catalina 30 "Kestrel"
Catalina 387 " Parrot Cay"
Credo quia absurdum
MHBsailor
Post by MHBsailor »
Thanks Chris! I think I came across it in the v-berth area but it didn't fit anywhere up there - it was one piece, varnished, and looked like each end went into a slot.
MHB Sailor
Moonshadow
Post by Moonshadow »
Looks just like my Typhoon Senior.
That is normal.
appletim1
Post by appletim1 »
No worries about that with a CD 22.
