CD25D mast step
CD25D mast step
I am getting a little water leaking around the top of the compression post on my 25D. Since I have the mast down this year, I could rebed the mast step.
It looks like there are four through bolts that go through the ring at the top of the compression post in the cabin.
Anyone have experience with this? Or should I just caulk around the bottom of the step and leave well enough alone?
John
John
Re: CD25D mast step
Yes you should re bed it. Caulking around the base will leave well enough alone, which at this point, is a leaky mast step. Eventually, that leak is likely to create even greater problems, Steve.
Re: CD25D mast step
Since you will then have some sort of bedding compound or caulk you can work on re bedding all sorts of deck fittings before they start to leak, Steve.
- Joe Myerson
Re: CD25D mast step
I've been having the same problem. looks like a good winter or early spring project.
--Joe
--Joe
Former Commodore, CDSOA
--Capt. John Smith, 1627
Re: CD25D mast step
It really should not be a difficult task, although familiar with how that can turn out. It looked like there were four bolts. Remove them, remove the base, clean up, apply butyl tape and reassemble. It only takes a few minutes when they show it on television.
Steve
Re: CD25D mast step
I have yet to complete a project on any boat that only took a few minutes.steveg wrote:It only takes a few minutes
Re: CD25D mast step
I meant to use the font for sarcasm when it was suggested it should only take a few minutes. Sorry about any misunderstanding.John Stone wrote:I have yet to complete a project on any boat that only took a few minutes.steveg wrote:It only takes a few minutes
Steve
Re: CD25D mast step
Steveg
I was only being humerous. I routinely underestimate the time it takes for everything I do on the Far Reach. It's a running joke in my family. It's a badge I wear with perverse pride.
John
John
