Flywheel Puller Volvo MD2B part # 884078
Balestrand
Post by Balestrand »
Does anyone have any tips for finding a 4-bolt flywheel puller that will fit with a 1975 Volvo Penta MD2B? This is on my CD 28. The Volvo Penta puller part number is 884078, but it is no longer manufactured. The bolt holes are in a 6x6 cm square, or 8.5 cm on the diagonal diameter.
Where does one find a large, very sturdy 4-bolt puller?
~Robert
CD 28 "Spondee"
Camden, ME
Frenchy
Re: Flywheel Puller Volvo MD2B part # 884078
Post by Frenchy »
Hi Robert - I think you will have to scan the web for something that will fit. Then you'll probably have to buy some longish
metric bolts to fit the flywheel and settle for pulling on two. Here's a possibility, but you'll have to verify that the bolt slots
will accomodate the 85mm spacing. - Jean
https://www.harborfreight.com/heavy-dut ... 63268.html
