Question for CD 22 owners - outboard fuel line
s2sailorlis
Post by s2sailorlis »
How have you been routing your outboard fuel lines?
I'm converting my Tohatsu 5hp from internal to external tank.
It seems awkward having fuel hose run from under hatch opening at bottom...Up and over the stern deck to motor. (I've got the Spartan bracket).
My thought is drilling hole in lazarette where tank is stored so the hose runs thru aft bulkhead... then route it thru the aft deck via a bronze deck fitting OR possibly thru stern.
______________
Rick
1984 CD22
shavdog
Re: Question for CD 22 owners - outboard fuel line
Post by shavdog »
My 22 had a hole thru the back of the tank locker to the aft bulkhead and another hole thru the stern...with a rubber oring washer to fit the opening
s2sailorlis
@shavdog, thanks much. sounds similar to what I'm wanting to do. since I have the Spartan bracket, I am thinking an access hole thru the stern makes the most sense, should allow for enough room to bend on the fuel line into the engine inlet.
______________
Rick
1984 CD22
