2 speed Garhauer mainsheet tackle
freitknecht
Post by freitknecht »
Anyone have any experience or opinion about 2 speed mainsheet tackles, particularly Garhauer?
Vincent
Re: 2 speed Garhauer mainsheet tackle
Post by Vincent »
I have no direct answer for you other than Garhauer makes high quality equipment. I have several blocks and a 4 part handy billy, and it is superb, and I think lower priced than Harken, Lewmar, etc.
mgphl52
Post by mgphl52 »
I haven't used the Garhauer version, but I do know you need a really well done, end-to-end splice to make it work best. Otherwise you will be constantly re-aligning the mainsheet.
David Morton
Post by David Morton »
I inherited that Garhauer setup when I bought my CD31. The PO added it when he moved the main sheeting from mid-boom to end of boom, with the new traveler on the transom. I have found the 2 speed rig to be very useful, and, though there are now two main sheets cluttering up the cockpit it is surprising how little the two lines actually interfere with each other. I rarely get a tangle or a kink at the clamp and the lines generally run smoothly. The additional mechanical advantage is helpful in a brisk breeze with a full sail. i'll try to set up a picture for you.
David
Is he still wrong?
" anonymous, Phoenician, circa 500 b.c.
