Source for bronze bar
mashenden
Location: "Nautica" CD-36 #84, Ty-K #83, & CD-10 #1539 in Urbanna, VA. 4 other Tys in past
Post by mashenden »
My teak coamings are splitting where the cleats are attached. Barring a better approach, I plan to epoxy the teak, then reinstall the cleats, but adding a bronze plate to add some structural strength. I figure I'd use something around 1/8" thick, and 2" x 4".
Does anyone have any suggestions on where to buy stock bronze and what type would be best to use?
Matt Ashenden
- I used to like boating and fixing stuff, then I bought a couple of boats and now I just fix stuff :)
Bob Ohler
Re: Source for bronze bar
Post by Bob Ohler »
McMaster Carr perhaps? Also, Spartan makes a triangular backing plate that goes on the opposite side of the coamings... if that gives you anything.
Bob Ohler
CDSOA Member #188
CD30B, Hull # 335
sv Aloha Spirit
bottomscraper
Post by bottomscraper »
Here is an old thread that you may find interesting:
http://www.capedory.org/board/viewtopic ... lit=bronze
I'm not sure what the "right" bronze is but 954 Aluminum Bronze has held up just fine protecting our bowsprit since 2010.
Here are some sources for small quantities of bronze and brass:
McMaster Carr:
http://www.mcmaster.com/#standard-bronz ... s/=12r8pkw
Online Metals:
http://www.onlinemetals.com/
Speedy Metals:
http://www.speedymetals.com/
I have ordered from all of the above without any problems. McMaster doesn't give you a shipping estimate but they charge fair prices and ship fast. If you order from them you may want to also get some fasteners, cotter pins etc.
There is also Atlas Metals, I have never ordered from them:
http://www.atlasmetal.com/
Lastly you may want to check Ebay, you may find some bargain cutoffs.
Rich Abato
Nordic Tug 34 Tanuki
Southern Maine
http://www.sailmahalo.com
mashenden
Post by mashenden »
Bob Ohler wrote:McMaster Carr perhaps? Also, Spartan makes a triangular backing plate that goes on the opposite side of the coamings... if that gives you anything.
That has potential. Thank you. Price wise it isn't too much more than the raw material is likely to cost. If the bolt pattern used in '83 has not changed, this could be the best option.
Matt Ashenden
mashenden
Post by mashenden »
Thank you Bottomscraper/Rich for the references. They are very helpful.
Matt Ashenden
Kevin_P
Location: Former owner of "Meridian"1977 CD30C #58Milwaukee, WI
Post by Kevin_P »
Spartan Marine sells a bronze backing plate with holes/etc. for the cleats that are mounted on the coamings. A few years back I purchased and added a cleat on my coamings for rollerfurling. The backing plate adds a lot of strength, and it looks pretty. :-)
Kevin
Kevin Petajan
"Vegvisir" - Young Sun 35
1977 CD30C #58
Milwaukee, WI
mashenden
Post by mashenden »
Kevin_P wrote:Spartan Marine sells a bronze backing plate with holes/etc. for the cleats that are mounted on the coamings. A few years back I purchased and added a cleat on my coamings for rollerfurling. The backing plate adds a lot of strength, and it looks pretty. :-)
Kevin
Yes indeed. I am looking into that option to see if the hole pattern matches my cleats from '83.
Thank you.
Matt Ashenden
mashenden
Post by mashenden »
Upon measuring the hole pattern, the Spartan backing plate (B202) looks to be the same hole pattern as was used in '83. I'm going to order 3... and as previously noted, they will look pretty :D
Matt Ashenden
tvangilder
Post by tvangilder »
silicon bronze plate can be bought at atlas metal sales in colorado. atlasmetal.com
Thad Van Gilder
CD36 #53 "NIrvana"
Home Port: Rock Hall, Md
