CD 26 Hull Decorative Tape Below Teak Rail-Replace
dgsail
Location: 1986 Cape Dory 26, Hull 50, Bridget, Montrose Harbor, ChicagoOriginal Owner
Post by dgsail »
The brown taping on the hull that runs bow to stern, underneath my teak rail has rubbed off from the friction of fenders at the dock. I would like to replace it and prevent this in the future.
Has anyone found a tape to replace the original?
What are the steps for this project?
When I hang the fenders from the life lines, how can I prevent them from rubbing the tape away?
Debbie Garrity
Re: CD 26 Hull Decorative Tape Below Teak Rail-Replace
It's known as a "cove stripe". I believe you will find everything you need here;
http://www.capedory.org/board/viewtopic ... ove+stripe
It would be difficult to advise you on fender placement without a photo of your particular situation. Usually it's just a matter of raising or dropping them a few inches but I imagine if it was that simple you'd have done it already. Perhaps a fender board is your solution. That would keep the fenders off your hull completely.
