Loss of power when shifting in reverse
Mike Davis
Post by Mike Davis »
At the end of last season, I noticed that whenever I shifted the transmission in reverse, and gave the engine some increased throttle, the engine lacked power and sometimes died. This happens only in reverse. Has anyone ever encountered such a problem and what is the solution. Thank again.
Mike Davis
cd31
Re: Loss of power when shifting in reverse
Do you have the single lever control or the two lever?
Mike Davis
I have the single lever control for shifting.
Check the linkage. Put the lever into reverse and see if you can advance the throttle at the engine. I think the linkage is loose and needs adjustment. Do you have the manual for it?
Joe Myerson
Post by Joe Myerson »
I agree with Tim. I found that a key piece of my one-lever shift linkage had rusted badly. The linkage froze, and in forcing the cable it busted. I could still run the engine in forward, but no reverse.
This year I cleaned it with Naval Jelly, wire-brushed it and painted it with Rustoleum. Will see how it works out.
Joe
Former Commodore, CDSOA
--Capt. John Smith, 1627
