Omnia Oven
Share your provisioning secrets and solutions as well as your recipes.
oldragbaggers
Omnia Oven
Post by oldragbaggers »
Does anyone use an Omnia Oven or Wonderpot for baking aboard. If so, with how much success?
Lance & Becky Williams
Happily retired and cruising aboard our dreamboat, Anteris
http://www.sailblogs.com/member/anteris/
https://www.facebook.com/oldragbaggers
Re: Omnia Oven
oldragbaggers wrote:Does anyone use an Omnia Oven or Wonderpot for baking aboard. If so, with how much success?
I was unfamiliar with the Omnia so I checked out a website which included a video. It looks fine but a bit pricey.....what isn't :wink:
It's essentially a Dutch oven with an extra bottom flange to keep the direct flame from scorching the contents. In your everyday cast iron dutch oven (in a campfire situation) you don't have a direct flame to contend with, they go onto a bed of embers and therefore cook without scorching.
If you don't have an oven on the boat it seems like a neat solution. Hopefully the aluminum pan is on the thick side, although I didn't see any mention of a non-stick surface which would be helpful.
Here's an example of a real cost effective stovetop baking solution.
https://m.youtube.com/watch?v=F_XlGx7P2t0
barfwinkle
Re: Omnia Oven
Post by barfwinkle »
I use one aboard Rhapsody and seems to work pretty well. I do find that I need to rotate (flip) the bread products so both sides get cooked through and through.
Happy Thanksgiving
Bill Member #250.
oldragbaggers
Re: Omnia Oven
Thanks everyone for the replies!!
Happy Thanksgiving to you all.
