I own a 1976 Cape Dory 25 with plastic ports. They are old and I am worried they will blow out if a strong wave hits them. They need to be replaced.
Solution:
Can we remove the plastic port windows and replace them with fixed bronze windows? The dimentions of the windows are as follows:
(2) Large Windows: L = 32" H = 7.5"
(4) Smaller Windows: L = 14" H = 5.5"
If there are other people interested in replacing their windows on vintage CD25's please let me know and I will see if New Found Metals can build these replacement windows.
Economies of scale will help all us who want bronze windows on their CD25.
My first choice would be to build the ones that open however this will require significant modifications to the cabin. I think I can design ones that simply fit in the same opening as the plastic windows. They can be caulked and bolted into place.
This solution would improve the asthetics of all older CD25's.
Please email me if you are interested in helping me solve this.
SeaStar
CD25
-Paul
pwreiss@aol.com
CD 25 Portlights Replacement Solution!
Re: CD 25 Portlights Replacement Solution!
I am moderately interested in the window solution that you come up with. I am a new owner of a cd25 (1974). I will be putting her in the water this spring in Chicago.
digistill@aol.com
digistill@aol.com
I have a cape dory 25 , 1977 with plastic windows. I definitely want them replaced. Hope to hear back from you.
Lisa
Lisa
- tartansailor
Yes, I too am interested.
Thanks for the initiative.
Viam Inveniam Aut Faciam
I wonder when they made the change to plastic frames. I'm fairly certain my 1974 CD25 had aluminum frames.
Sir Isaac Newton
Sir Isaac Newton
Paul,
I don't have a solution to this, however, I just became aware that the windows in my Cape Dory 25(1977) are not original and should be brass! Wow what a difference to the aesthetics! I will follow this discussion.
