Penguin is in the water in Georgetown, SC. She is in great shape and ready for extensive cruising or living aboard. Come and see her and take her out for a trial run if you would like. Here are her details.
HULL
Hull # 14, 1986
LOD: 29 ft 11 in
LWL: 26 ft 6 in
Beam: 11 ft 5 in
Draft: 3 ft 11 in
Bridge Clearance: 47 ft 0 in
Displacement: 11,500 lb
Ballast: 4,500 lb
Sail Area: 442 sq ft
Hull Speed: 6.9 knots
Fuel efficiency (measured at 6.0 kn cruising speed): 9 nm/gal
DECK
Three-sided pilothouse with aft enclosing canvas
Pilothouse opening side windows and center windshield
Walk-thru transom door
Teak swim platform
Laminated teak bowsprit w/anchor roller
25 lb CQR anchor with 20' chain and 200’ nylon rode
22lb Danforth with 6' chain and rode
ACCOMMODATIONS
Private forward stateroom with large V-berth and bureau
Opening Bomar hatch over V-berth
Spacious head compartment with sink and shower
Roomy U-shape dinette converts to double berth
Hanging locker
Eighteen storage compartments and drawers
Diesel cabin heater
Personal cooling fans in V-berth
8 opening bronze ports with screens
Teak cabinetry throughout
Teak and holly cabin sole
GALLEY
Origo 2 burner alcohol stove
Microwave
Toaster-oven
Crockpot
Toaster
Electric coffee pot
Built-in 6.2 cu ft ice box
Engel 40-qt refrigerator/freezer
Double stainles steel sink
Electric and manual water pumps
Laminate counter tops
SAILS AND RIGGING
Deck-stepped mast
Hallett In-mast roller-furling main (new in 2012)
Hallet roller-furling jib (new in 2012)
Hood roller furling
Pilothouse top main sheet traveler
All sail controls inside pilot house
MECHANICAL
Westerbeke W46 4-cyl fresh-water cooled diesel, new 09/2010
800 engine hours
Hurth V-drive
Bronze shaft and bronze 3-blade propeller
Racor fuel filter/water separator
Bronze seacocks
TANKAGE
Fuel: aluminum 50 gal with gauge Fresh water: polyethylene 70 gal
Holding tank:polyethylene 25 gal with macerator pump
12VDC ELECTRICS
170AH house bank with two 12V marine batteries and switch
Complete bonding system including keel Dynaplate
All lighting converted to LED
110VAC ELECTRICS
AC panel with 30-A dock power cord
6/110VAC duplex receptacles in cabin
220W Kyocera PV system charging 440AH bank of gollfcart batteries
100AH/day clear-day solar gain
2,500W 110VAC inverter
ELECTRONICS
Furuno 16-nm LCD radar
Raymarine autopilot
Raytheon VHF
Datamarine depth and speedlog
iPad mini with GPS navigation apps including all charts for Nova Scotia to Bahamas
Toshiba flat-screen TV with Leaf antenna and DVD player installed in V-berth
PRICE $54,900
Call (207)720-0945
Cape Dory MS-300 Motorsailer for sale
- 2098796_1.jpg (36.81 KiB) Viewed 796 times
- 30 cape dory 300 ms 163.jpg (66.86 KiB) Viewed 796 times
