Refinishing bulkheads on a CD28
CRISSCROSS
Location: 1978 CD28 CrissCross Hull#188 New Suffolk, NY
Post by CRISSCROSS »
I know the finish on the bulkhead is not real wood so sanding and varnish are out I guess. Any ideas on how best to clean this up? Its not too bad but are showing their age and have a few small holes I'd like to fill.
Thanks for any advice.
Bruce
s/v CrissCross
Smooth sailing
Bruce Hotchkiss
s/v Criss Cross
pete faga
Re: Refinishing bulkheads on a CD28
Post by pete faga »
Bruce
I believe you have paperbacked veneer.
Try sanding with 320 on a portion that you cannot see.
Pete
pete faga
Post by pete faga »
Joe the woodworker has a great web site on installing paperback veneer.
He said most people use furniture polish!
I would test a small portion and see if you like the results.
My veneer sill looks pretty good after 40 plus years but I might try light sanding and some polish and see what the results are in a small area before I do the entire veneer.
Pete
oldragbaggers
Post by oldragbaggers »
Maybe I just got lucky so I am in no way advising anyone else to do it, but I cleaned, sanded, and varnished the bulkheads on my CD28 and had no problem with them whatsoever.
Lance & Becky Williams
Happily retired and cruising aboard our dreamboat, Anteris
http://www.sailblogs.com/member/anteris/
https://www.facebook.com/oldragbaggers
CRISSCROSS
Wow they look great. What grit sandpaper did you use and what did you clean with? What year is your CD? Looking at your sink where I have a hanging locker on my 1978.
Smooth sailing
Bruce Hotchkiss
s/v Criss Cross
oldragbaggers
I did the CD28 in 2008-2009 (we no longer have it). It was a 1981. I am now beginning this same process again with a 1982 CD33 (and I'm a bit overwhelmed by how much more wood there is).
To be honest I cannot remember what I used to clean it. I do not believe it was anything with acid, or even anything specifically for boats. It might have been Murphy's Oil soap but I am not certain. It was likely whatever cleaner I had available in the kitchen cabinet.
On the plywood surfaces I make sure I don't saturate the wood, I just wipe and wipe and wipe (and wipe). I use an old wash cloth or piece of towel, dipping and wringing it frequently, but I wring it well so not to get the wood really wet. This really just removes surface dirt but will not remove any deep stains. After the wood was thoroughly dry I sanded with 220 grit sandpaper, and I used an electric palm sander, but I sanded very lightly, what my mama would have called "a lick and a promise." I was a bit more aggressive with the solid wood trim where it was needed. On that I used a abrasive pad to clean. My process did not bleach the wood and would not remove any mold, mildew or black areas, but I was fortunate on that boat (and the one I am doing now) that the wood was in good shape, just generally dirty. The ash ceiling strips I removed from the boat so I could really clean and sand those well. I wanted to restore the light golden color and they came out beautifully. The wood has really darkened on the CD33, and I have considered trying to use teak cleaner and bleach but I am a bit scared to, as someone else has mentioned it might damage the glue in the veneer and cause it to raise. I think I will just do this same process again and if it's dark so be it.
I used Captains Spar varnish on that boat. I plan to use Epifanes this time.
Good luck with your CD28. They are such lovely boats and I loved the feeling of warmth and elegance that having varnished wood gave her. Having varnished wood on the 28 spoiled me and now I wouldn't dream of not doing it. I can't wait to see my CD33 gleaming like that.
The picture looks phenomenal. Before you start the process on your new CD33 perhaps you'd like to perfect your technique on my CD31 first. Practice makes perfect.
oldragbaggers
Jim Walsh wrote:The picture looks phenomenal. Before you start the process on your new CD33 perhaps you'd like to perfect your technique on my CD31 first. Practice makes perfect.
:D The world loves a comedian!!! :D
