I'm looking for any suggestions on sourcing parts for my somewhat ancient Horizon Speed Log, (Model SL45) specifically another impeller. I've recently replaced the impeller with a new one, but understand they are no longer available from Signet Marine, which now sells "newer" versions of this model.
Any tips, suggestions will be very welcome. Thanks - Lou (CD33, Hull #63, located in San Diego)
Standard Horizon SL45 Digital Speed Log
- Location: U4rhea CD25 and relative partner of Ty Angela Marie now in Australia
Re: Standard Horizon SL45 Digital Speed Log
Here's the stuff, check out what you wish. the red impeller seems like it could work.
John
John
- signet.png (1.77 MiB) Viewed 270 times
Hello John, yes I agree the "red" impeller might work, (looks like the correct/similar size to my existing unit) would you consider just selling that portion of the unit? Did the unit work, before you removed it from the vessel? Looks like bottom paint on it, so I suspect it can be cleaned up, and hopefully become operable.
I can mail you a check, and when you receive it, have the package sent to my home. Thanks in advance - Lou Lepis
