Where can I get a boom crutch for my Cape Dory 10
Sealyham
Post by Sealyham »
i am looking for some advice about a boom crutch for my Cape Dory 10. My boat sits at a dock and I cannot get there every day. I don't like to leave the boat open to the weather, so I'd like to get a boom tent. But I'd need a boom crutch to make the whole thing work. Suggestions?
mashenden
Location: "Nautica" CD-36 #84, Ty-K #83, & CD-10 #1539 in Urbanna, VA. 4 other Tys in past
Re: Where can I get a boom crutch for my Cape Dory 10
Post by mashenden »
I made one from a piece of wood then epoxied pins that I cut off brass oarlocks into each end. The crutch fits beam to beam in the aft oar sockets. I shaped the wood to have a curve and cut three notches for the mast and other spares. I also cut some 2" - 3" holes in a few places because I thought it would look good but found they were ideal for threading bungees through to hold the spars in place and hold the oars in place. I lucked into that:)
You can see it in the mess during my transom reconstruction project.
Matt Ashenden
- I used to like boating and fixing stuff, then I bought a couple of boats and now I just fix stuff :)
Sealyham
Post by Sealyham »
What a super idea-thanks! I am going to copy you! :D
mashenden
Post by mashenden »
Cool! Glad I could help.
When epoxying the pins in place, I did one at a time and put the board in place while it set up. This ensured correct pin alignment. I also put tape around the socket and grease on the pin to make sure epoxy did not set up in places it did not belong.
Matt Ashenden
Dick Villamil
Post by Dick Villamil »
What year is your CD10? I have the same double hull version and understand that they were limited in production. I also just finished one of the solid battens to go with the others that actiually have batten pockets. I will use your ideas in order to make a place for the oars etc. I would love to see any photos of your CD10 during and after the restoration. I will be placing some images in the "project" section sometime in the next few weeks. She is a sweet rowing boat - haven't tried sailing it yet however.
mashenden
Post by mashenden »
Try as we might, I have not found a reliable way to determine the year.
I have enjoyed sailing mine, once in a small craft warning. Late last year I blew the sail out and have not made time to sew together my Sailrite sail kit yet. I got a bit distracted fixing and sailing my CD-36. I named the 36 "Nautica", and plan to name the CD-10 "Naughty".
Matt Ashenden
