I had seen previous posts and the video of the cajun tiller tamer and gave it a try on our first sail yesterday. It worked really well under power and light winds, but not so well when the winds built up to 10 MPH. How many wraps are most people using? Also, is there a specific way the wraps are to be made as the video shows a nice tight wrap, but mine had a tendency to spread apart all along the tiller?
Cajun Tiller Tamer - Tips for use?
Moderator: bobdugan
Steve
Pleasant Journey, Morgan 35
Previously:
'85 CD 26, Hull No. 30
'74 Typhoon Hull No. 789
Previously:
- Terry
Lake Lanier, North Georgia
www.jonahzsong.com
Re: Cajun Tiller Tamer - Tips for use?
I've tried several methods similar to what you are speaking of, mostly to self-steer while going forward to raise the main. In light winds or under power, it works fine, as you say. Under more wind, it doesn't because it isn't self-steering, but for holding a fixed course, for a short time, it seems to me.
To self-steer, without a couple grand worth of gear attached to the stern, there are several methods available. There are a couple good videos out there to. Search 'self-steering' and check them out.
All the best.
All the best.
Lashing your helm is not steering. If the sails and helm are balanced (i.e., you're not turning) and conditions stay the same, your heading will stay the same. Otherwise, no.swhfire21 wrote:I had seen previous posts and the video of the cajun tiller tamer and gave it a try on our first sail yesterday. It worked really well under power and light winds, but not so well when the winds built up to 10 MPH. How many wraps are most people using? Also, is there a specific way the wraps are to be made as the video shows a nice tight wrap, but mine had a tendency to spread apart all along the tiller?
I prefer a line going from coaming to tiller, taking a round turn and then making off the bitter end with a rolling hitch. It's easy to adjust and unlike the cajun alternative, you can keep the force at right angles to the tiller. I suggest some chafe gear on the tiller if you're a frequent user.
Thanks for the feedback.
I basically single hand all the time as the Admiral is just along for the ride when she is on board (her preference). So I am basically just trying to lash the tiller for a few free handed moments at a time. Anything longer than that and I heave to (a lot more comfortable in the 26 than it was in the Ty).
I had a tiller tamer on my Ty but found that it would bite my fore arm quite often and painfully if I did not pay attention to my grip or tried to rest my arm on the tiller. I like Neil's idea as its just plane simple, not sure though about cutting the cockpit in half with another line. The cockpit on the 26 is quite short to begin with, I'll have to see where this would fall in reference to the helm and admiral's favorite seating.
Steve
Previously:
Previously:
