I'd like to refinish the cabin sole on my '82 CD 28. I've read a number of articles, books, and the archives but am not sure what finish was applied by the factory. Since it's a thin veneer would sanding alone prep it for the varnish I intend to use?
Thanks for any thoughts and guidance.
Guy
Cabin Sole Refinishing
Re: Cabin Sole Refinishing
Guy,
I think that you might get in trouble sanding a thin wood veneer. It already has some wear and tear on it since it was first installed.
Is it just dirty? You might try cleaning it first. Don't use any floor finish that contains any wax type shining agent. If you do, the final finish won't adhere properly.
"If I rest, I rust"
Voting Member #490
Voting Member #490
I would use a heat gun to remove the varnish, then follow these instructions:
https://www.youtube.com/watch?v=jYGKqu_ ... 9&index=11
Kind Regards,
Adam
Adam
- johnny of STORK
Taos, NM
San Carlos, Sonora, MX - Contact:
I sanded mine lightly with a palm orbital, and varnished with Verathane. Looks and lasts great.
Johnny
Johnny
