PANAMA CITY,FL
Boat is in the water now.
Year: 1980 Trailer: Not Included
Make: cape dory Use: Salt Water
Model: sloop Engine Type: single inboard
Type: sailboat Engine Make: yanmar
Length (feet): 27 Primary Fuel Type: Diesel
Beam (feet): 8.6 Fuel Capacity (Gallons): 6-10
Hull Material: Fiberglass Hull ID Number: cpdj0159m80b
Rigging: Sloop, Cutter For Sale By: Private Seller
Keel: Fixed
Seller's description
FOR SALE
Compact layout with 5'9" headroom in the salon and foreabin with nice wood trim and a 5'9" V berth.The head follows to port with a manual M.S.D. and privacy curtain. Across from the head is a storage closet with three shelves. The salon in next with 24"x26" portside dinette table and seating on both sides with 44" wide settee to starboard. A small galley folows the starboard settee with Origo 3000 alcohol stove, manual freshwater stainless steel sink and ice box.
Electronics
Navico TP100 tiller pilot
plastimo France cockpit bulkhead mounted compass with built in inclinometer
horizon depth finder
apelco dxl6399 loran c
horizon intrepid vhf radio, cassette stereo
separate ac and dc panels
two batteries
battery selector switch
statpower true charge 10 battery charger
Deck
2Lewmar #7 single speed winches on cockpit gunnels,2 lewmar #6 single speed winches on mast. traveller mounted aft of cockpit. deck stepped mast with single spreader.sails consist of mainsail, 110% jib, 150%jib, cruising spinnaker
stainless steel stern boarding ladder
teak hatch boards
tiller steering
danforth #1B10 anchor
lunch hook anchor
deck light on mast
cockip cushions
6 brass opening ports
20x20 forecabin opaque hatch
dorade
windex
throw ring
additional
2 blade bronze prop
aluminum fuel tank with top mounted gauge
olin flare kit
first aid kit
brinkman q beam handheld searchlight
bimini
fire extinguisher in lazerrette and in salon
boat hook
brass inclinometer on salon bulkhead
We do not know how many hours are on the engine. The boat was out of the water in 2009 for bottom job, rigging was redone around the same time. We have not used the boat over an year and half. Boat needs cosmetic repairs and teak to be redone.Engine was running good for us when we used the boat. Feel free to ask any questions.
Thank you for looking.
$6900 CD27 for sale
$6900 CD27 for sale
- bottom paint in 2009
- P2180598.JPG (626.93 KiB) Viewed 2344 times
- P2180594.JPG (681.23 KiB) Viewed 2344 times
Re: $6900 CD27 for sale
Gorgeous vessel-wish I were in the market for such! Hope she sells quickly for you.
Skeep
Hi, is the boat still available? Thanks!
I own a Cape Dory 25, looking for some thing a bit bigger.
Would to chat with you about your CD 27.
jrogash
508-728-1205
jrogash@aol.com
jrogash
508-728-1205
jrogash@aol.com
