There is already a lot of good information that has been posted. Try doing a search for chainplates and you will find links like:
http://www.capedory.org/board/viewtopic ... al#p127877 and more pictures of Fred's chainplates can be found at:
http://www.sbastro.com/FeNIX/mainFrameSet.htm See Projects/Interior/Salon and Projects/System/Rig.
Paul Calder had some interesting thoughts about what material to use:
http://www.sailfeed.com/diy-chainplates ... -materials and blogs about his experience:
http://www.sailfeed.com/diy-chainplates ... -stainless and http://www.sailfeed.com/installing-chainplates
I modeled my chainplates after Fred's posts, with advise from DaveCD28.
- For the external chainplates, I used 316 bar purchased online (take a look at speedymetals.com). The back-stay and upper shrouds were 3/8" thick x 1 1/2" wide and the lower shrouds were 1/4" thick (I will need to measure the actual lengths as I may have cut them). For the backing plates, I used 304 bar, 1/4" thick.
I cut the holes with a small bench press, cobalt bits and lots of cutting oil. The bolts are A2, 304.
I positioned all the eye holes to line up with the original eye pads.
I made a frame to bend the chainplates for the backstay and lower shrouds with a hydrolic jack. The backstay needs a bend of about 45 degrees and the lower stays may have been in the neighborhood of 15 degrees? It helps to attach the chainplate with one bolt and then tighten up on the shroud to find the proper angle fore and aft.
I used an oscillating multifunction tool to cut the fiberglass off the rebar and an angle grinder with a 4 1/2" cutting disk to cut the rebar and then a 60 grit flap sanding wheel on the angle grinder to clean it all up.
I added reinforcing fiberglass and bedded the backing plates in thickened epoxy with chopped strands of fiberglass.
The dust and epoxy fumes are pretty noxious. I now use a full face respirator when I do any similar work.
I haven't yet decided if I want to make all the standing rigging uniform with 1/4" wire or keep 3/16" lower shrouds. I'll make a decision in the fall/spring when I lower the mast.
At first, I just cut notches in teak for the chainplates. I later discovered that the deck had deformed and cracked above the old backing plates. When the standing rigging is out of the way, I will fiberglass over the hull deck joint in the area of the chainplates.
I still need to "polish" the plates (another winter project).
Chainplate on transom:
Backing plate bedded in thickend epoxy:
Top sides:
I will glass over the joint here as well:
Bending the bars:
