For Sale: Trinka 8 yacht tender, trailer and 2 hp Honda 4-st
thomheley
Post by thomheley »
A rowable and sailable yacht dinghy that keeps you and your gear dry when the others are getting drenched!
The towable rowing and sailing yacht tender that holds up to the rugged cruising service that destroys most toy dinks.
Looks like the fine boat she is...not a basement bargain or jelly bean.
A rigid, fiberglass yacht dinghy that doesn't have to be blown up, won't deflate, and won't flip over in high winds.
TRINKA 8 Specifications
• LOA: 8.0 feet (2.43m)
• Draft
Board Up: 4 in. (10.1 cm)
Board Down: 28 in. (71 cm)
• Beam: 48 in. (122 cm)
• Sail Area 38 ft2 (5.9 m2)
• Weight 85 Lbs. (38 kgs)
• Maximum Capacity:
3 Persons or 380 Lbs.(172 kgs)
450 Lbs. (204 kgs) persons, motor, gear
• Max HP: 2 HP Motor
Includes trailer and 2 hp Honda 4-stroke outboard
Asking: $ 2300
248-644-0297
thomheley@gmail.com
Additional Pictures Available
Trinka 8
Trinka 8
Trinka 1-72.jpg (702.99 KiB) Viewed 344 times
