I found the outfit that made all the original Cape Dory teak molding trim but they are not sure which specific one was made for the CD27 manufacturing runs.(the measurements are apparently all a little bit different)
One good friend on the Board here offered to let me check his trim on his CD28 but on the off chance there's a difference I really need to know what the specs for the CD27 trim work out to be.
Is there anyone on the Board with a CD27 already equipped with the trim molding who could let me have measurements and a "sectional" sketch so I can order the right stuff from the teak supplier? He just has to know which cutters to use!
Glad to cover expenses, or obviously if there's a CD27 here in the SE CT/RI area and you can let me check it out, I'll be glad to come over and make a rubbing
Thanks!!!
Yves
alphee@tinyradio.com
