My Typhoon came with a British Seagull motor, well I've decided that it time to change to a real motor, with a reverse. I want a motor that shifts into reverse rather than turning the motor 180 degrees. The smallest motor with a shifter that I have found is a 5 horse. I am looking for a good used motor if possible. Will a regular length shaft work with the Spartan bronze motor mount or do I need the long shaft.
I am open for suggestions on makes of motors and size.
jkingrea@flash.net
Motor for Typhoon
Re: Motor for Typhoon
I use a Tohatsu 5hp with integral tank and long shaft. (You will need the long shaft!) Spec sheet says 44# however which is a bit heavy for the boat. It definitely provides more than enough power for my needs. I'd move down to a lighter 4 hp with only a neutral but for the times that we drop a hook and go ashore for lunch and then need the reverse to get the hook free. There are lots of posts about this issue.
Serge
serge@srtrop.com
Serge
serge@srtrop.com
If you search past postings there is lot's of imformation on outboards for the Typhoon. The consensus seems to be in the 3.5 to 4 hp long shaft,and as always there is a trade off,no reverse in this size of motor that I am aware of.My Typhoon came with a British Seagull motor, well I've decided that it time to change to a real motor, with a reverse. I want a motor that shifts into reverse rather than turning the motor 180 degrees. The smallest motor with a shifter that I have found is a 5 horse. I am looking for a good used motor if possible. Will a regular length shaft work with the Spartan bronze motor mount or do I need the long shaft.
I am open for suggestions on makes of motors and size. Jim,
Robert
wskyr3d@aol.com
Check out the new 4 stroke Yamaha 4hp engine w/ internal tank. I think the price is around $900+My Typhoon came with a British Seagull motor, well I've decided that it time to change to a real motor, with a reverse. I want a motor that shifts into reverse rather than turning the motor 180 degrees. The smallest motor with a shifter that I have found is a 5 horse. I am looking for a good used motor if possible. Will a regular length shaft work with the Spartan bronze motor mount or do I need the long shaft.
rodney
seaweed@snet.net
