stanchion bases
tuckandsue
stanchion bases
Post by tuckandsue »
All 7 of my stanchion bases need to be replaced as they are corroded right at the weld. 2 have broken off completely.
Is it possible to keep the flat part of the base and have a new pipe receiver welded on or do I need to replace the whole thing. They are stainless.
I have not been able to find, anywhere, someone that sells stanchion bases with the same bolt pattern.
The dimensions are 3 5/8" x 2 1/2" for the plate.
The holes are 2 3/4" center on outers and 1 1/2" inner.
The distance between the outer holes and inner holes is 1 3/4".
Anyone have any of these floating around someplace?
s/v Harmony
Cape Dory 28
1978
