In past contacts with surveyors, they have always said they perform a moisture test on the hull as part of the survey, some even saying they do so with a special moisture meter instead of a small plastic hammer. Each surveyor had known that the sailboat was in the water, had been in the water for some time, and would be hauled out of the water specifically for the marine survey.
Today I spoke with a marine surveyor who told me he would NOT perform a moisture test on the sailboat that I MAY be interested in because it will have been in the water for several weeks at the time of inspection and thus he cannot do a valid moisture inspection with a meter. He said the sailboat would have to sit on the hard for a minimum of 7 days before a moisture meter inspection could be done.
I found this statement contrary to what I understood every other surveyor had told me. All the others said they would be able to do a moisture meter test shortly after haul out.
Being the dummy that I am I went immediately to my "bible", that is, Inspecting the Aging Sailboat by Don Casey. I have read this book several times yet to my surprise I found the following statements at page 17 in a discussion of "moisture meters":
". . . moisture meters tell you very little about the interior of the laminate"
"On a boat that has been out of the water for several weeks, a reading around 5 percent suggests the hull is dry."
From the above I am assuming Mr. Casey is saying that if you want to use a moisture meter to determine moisture in the hull, if any, you need to have the boat out of the water for more than a week at a minimum.
What is the collective wisdom on this board about moisture meters
![Question :?:](./images/smilies/icon_question.gif)
I am guessing there is a simple explanation for my confusion. At least I hope so.
![Confused :?](./images/smilies/icon_confused.gif)
Also, as an aside, of all the marine surveyors I have spoken with in the past week not one said the survey would include going up the mast to inspect the mast. A few said "I can recommend a rigger to you but I do not climb the mast." Is this a new policy among surveyors or just an effort to get work for their rigger friends
