Prep for the "Long Haul"
CDSOA #1251
I'm getting INVICTUS ready for the trip down I-95 from Newport to DC.
What I've done so far:
She is sitting on the trailer with her mast pulled and stowed on deck. The mast is strapped down to pushpit and pulpit stanchions and at three places in between to deck hardware and is supported in the middle by two fenders. I've also pulled the spreaders and tied AND tie-wrapped at the rigging to the mast. The lifelines and stanchions have been removed and carefully stowed. I have removed all the unnecessary gear and consigned their delivery to the U.S. Navy's contracted moving company.
No dodger to worry about, but I think I would like to get one in the future
Anyone with long distance transport experience have any other suggestions?
Thanks!
Jeff
Thanks!
Jeff
“…It matters not how strait the gate,
How charged with punishments the scroll,
I am the master of my fate:
I am the captain of my soul.â€
kind of like prepping for a hurricane
Sometimes companionway hatches will bounce up and slide forward, so it is good if they are latched.
If rain is forecast, expect it to blow in through the front of a companionway hatch that lacks a sea hood.
Tod Mills
Tartan 26 project boat
Cape Dory admirer
Cape Dory admirer
- mahalocd36
Be sure to lock the boat; and lock/secure all cockpit lockers.
Sounds like you did a great job with the outside, we never removed lifelines/stantions. (2 hour ride with Brownell).
But we took off everything else we could from the deck.
Also, we would turn our rail mounted GPS attennae down/in so that it didn't stick up higher than the rail.
If you have attennae/wind indicator on the mast, remove it.
Below, make sure stuff is secured as well, as it goes over bumps/up and down hills, stuff will move around. Especially check that any liquids (like those that might be under your sink) are securely shut/secured.
Melissa Abato
www.sailmahalo.com
www.sailmahalo.com
- bhartley
CD25D #184 "Pyxis"
CDSOA Member #785
Turnbuckles.
Secure your turnbuckles. We have found that the jostling the boat gets over the road can quickly either work turnbuckles loose OR allow them to repeatedly whack into anything in the vicinity causing unnecessary damage to both the deck or whatever they're hitting and the turnbuckles.
Tie your tiller. Support the end of your furler if you have one.
Smooth travels!
Smooth travels!
It sounds obvious, but make sure all the portlights are dogged tight. I once saw a sailboat going down I95 with an interior curtain flapping out an open portlight.
I would consider removing and boxing up as much interior contents as possible and moving it yourself (or even shipping some of it). In addition to liquids opening and leaking, hard objects can bounce around and damage the woodwork.
When we trailered our "new to us" CD28 from Maine back home to Richland, WA, we wrapped the entire mast with two layers of the industrial "Saran Wrap". Available at our local UPS store, it held up great over the whole trip. It makes the mast much more aerodynamic and, even though you've tie-wrapped, it keeps things from flapping around.
Dave and Kathy
- jim trandel
- Location: '83 Typhoon Weekender, #1907 "Second Wind" Chicago Monroe Harbor
I trailered my Typhoon from Vermont to Chicago. I have a triad trailer and it was well balanced & performed very well. It all went well.
Here are my tips:
New tires and properly inflated.
Bearings inspected and greased.
Reduce speed to 55mph
Don't follow too close and anticipate stopping
Don't use a boat cover and and make sure your trailer straps ends are not flapping in the wind.
Goods Luck
Jim
Here are my tips:
Goods Luck
Jim
CDSOA #1251
Thanks for all the advice.
I like the plastic wrap on the mast idea and will definitely do that.
My trailer is a new Triad with electric disc brakes--it handles like a dream. My tow vehicle had no problem towing the trailer and boat from NYC to Newport in May, so I don't anticipate any issues.
Jeff
Jeff
Having trailered the hobie cat for years, I've found it is important to protect the heading edge of the boat -- lots of stones and things kick up on the highway any one direct hit can cause real damage -- indirect hits can leave nasty marks. You might think of wrapping the bow of the boat with some sort of protective cover (cardboard / plastic???). You might also consider using duct-tape across the leading edge of the hatch. I have heard of them lifting while being towed. As was already mentioned, there are a couple of good trailering / trucking prep lists on the 'net.
Luck!
Matt
Luck!
Matt
Me too!Oswego John wrote:Bob Chinn,
I chuckled out loud when I read your post.
CDSOA #1251
Mission Complete
Delivery went well. I took a lot of the prescribed advice and had no issues...although I didn't notice any significant fuel savings from the reduced prop drag! INVICTUS is now comfortably ensconced for the winter at Fort Belvoir in VA.
Thanks for the help!
Jeff
[img]http://picasaweb.google.com/jsturm70/Bo ... 2932050834[/img]
Jeff
