CD10 wood finish?
Nick Plakias
CD10 wood finish?
Post by Nick Plakias »
I am the new owner of a CD10 sailing dinghy. All the wood is bare and weathered. What finish should I use on it? Your wisdom and experiences appreciated!
nplakias@crocker.com
Larry :Lamagna
Re: CD10 wood finish?
Post by Larry :Lamagna »
I refinished my CD10 wood once, by sanding it down and putting on four coats of marine varnish and using steel wool in between coats, just make sure you wipe all the steel wool off or it will rust. Don't get any varnish on the fiberglass or it will yellow.
lamagna@mediaone.net
Harris
Teak or mahogany?
Post by Harris »
My CD 10 was an earlier boat that had mahogany seating and trim. For that you can't forget the cherry stain/filler before the spar varnish coats. Ahhhh.......cherry mahogony......The later CD 10's had teak seating and a full inner liner. I'm not sure how many were made this way as I have only seen one. the guy who sold me my CD 10 had replaced it with a later boat because of the more sufficient floatation. apparently he had had a life threatening experience involving swamping the CD 10. I tried it as an experiment and it barely floated. Caution advised.
hg@myhost.com
