Hard Spot
hilbert
Hard Spot
Post by hilbert »
I am replacing the cylindrical fuel tank from under the port deck to a rectangular tank in the starboard lazaret. I have built a frame that will secure the tank. The frame will be positioned between the main bulkhead and a piece of 3/4â€
hilbert
Follow up
Post by hilbert »
I ended up using 3/8" Core-Cell, a closed cell foam. It was easy to sand into a trapezoidal shape. Later I used the same material in replacing the core of the cockpit floor.
