Sink plumbing ?
Moderator: bobdugan
Jimbo
Location: cd 27 malletts bay vt. Cattail cd 14 #65 cd 10 #2251
Sink plumbing ?
Post by Jimbo »
On my cd27 the sink drain appears to be essentially the same as a houshold drain. The opening from the bottom of the basket is 2" then there is a plastic reducer that goes to a 1/2" hose. The reducer is toast and I can't find anything to identify a manufacturer. Does anyone know where this part might be acquired. I have done quite a bit of research and haven't seen anything similar. Any ideas would be appreciated. Jim
Stan W.
Forespar.
Post by Stan W. »
Forespar makes "sink wastes" with tailpieces to fit 3/4" id hose. They require a 2" hole in the sink. You have to buy the whole drain, but (surprisingly for Forespar) they're not expensive.
Jimbo
Found it ( I think )
Post by Jimbo »
