Cuppa
- David van den Burgh
Cuppa
A Sunday morning cup of coffee turned into a how-to blog entry about brewing a good cuppa joe aboard. If you're ready to get serious about your coffee while cruising (or at home), here's the link.
- jerryaxler
brewing cofee
"Approximately 170 degrees" If you really cared, you would be more precise.
Fairwinds and following seas,
Jerry Axler
Jerry Axler
Re: brewing cofee
Fine, 170-175 exactly. How's that? But seriously, there's better crema at 170 than 175. Your results may vary. No good deed goes unpunished, huh? Or else I need the aid of the new sarcasm icon that I hear is out there for a 1.99 download.jerryaxler wrote:"Approximately 170 degrees" If you really cared, you would be more precise.
- Dick Kobayashi
Perfect Alternative
http://www.sweetmarias.com/clevercoffee ... torial.php
No comment on beans - but this method cannot be beat for simplicity
Dick K
CD 25D Susan B #104
Mattapoisett, MA
CD 25D Susan B #104
Mattapoisett, MA
Re: Cuppa
I also have an Aeropress and it does make great coffee. I'm not to high tech on the temperature. I just heat the water to boiling shut the heat off let the pot sit for 10-15 seconds then pour it into the press. My only complaint with this method is it seems to use more coffee beans per cup of coffee.
I normally drink espresso though and grind my beans with a kyocera CM 45 CF grinder and use my little 3 cup stove top pot.
Sailing greenhorn
Typhoon hull #516
Stonington CT
Typhoon hull #516
Stonington CT
