CD25 chainplate repair: source or DIY?
Sea Cliff, NY
Member #1209
Rust stains are tracking down from my port backing plates, which upon inspection are flaking badly. I can only assume the chainplate underneath is toast.
The starboard side backing plate is 'rusty' but looks otherwise intact. I haven't popped the access panels to look at the bow/stern stays yet.
Is the repair a day/weekend/weeklong project? What would I expect to pay (ballpark) to have it done in my neck of the woods?
ditto
Ours are in identical, if not worse, condition. Other than what's already been written about on this board, we don't have any new ideas so we'll be interested in the responses, too.
Annie
Charleston, SC
CDSOA #1241
Charleston, SC
CDSOA #1241
- tartansailor
Well, That Really Has to be Addressed
This is what dropped out:
<a href="http://i76.photobucket.com/albums/j19/t ... 0_0232.jpg
"><img width="600" src="http://i76.photobucket.com/albums/j19/t ... 2.jpg"></a>
And this is my repair
<a href="http://i76.photobucket.com/albums/j19/t ... .jpg"><img width="600" src="http://i76.photobucket.com/albums/j19/t ... 7.jpg"></a>
To accomplish that, one needs to expand the round opening
access.
Place a towel or rags under to catch dropped tools.
Make plywood templates to fit before cutting stainless.
bmail if questions arise.
Hope this helps.
access.
Hope this helps.
- tartansailor
PM Sent
Kilgore,
I sent you a PM.
I sent you a PM.
Sea Cliff, NY
Member #1209
<a href="http://picasaweb.google.com/lh/photo/B- ... site"><img src="http://lh3.ggpht.com/_trq-yenw9CU/S6ZtP ... %20048.JPG" /></a>
<a href="http://picasaweb.google.com/lh/photo/yw ... site"><img src="http://lh5.ggpht.com/_trq-yenw9CU/S6ZtT ... %20049.JPG" /></a>
<a href="http://picasaweb.google.com/lh/photo/VQ ... site"><img src="http://lh3.ggpht.com/_trq-yenw9CU/S6ZtX ... %20052.JPG" /></a>
Progress, I think. Access was cut, the shrouds and stanchion removed , and flaked corroded mild steel backing plates chiseled off what appears to be the chain plate.
It's intact and stout, not budging even with a pry bar. I was under the impression only the CD27s and up had plates glassed into the hull. Everything above the plate is dry and hard.
Is that rust behind the innermost layer of glass on the hull?
Any suggestions at this point?
- tartansailor
Rust
Count on rust on the top surface because that is where water enters;
unfortunately.
unfortunately.
Sea Cliff, NY
Member #1209
Does anyone know if CD25s chainplates were constructed as described for a CD28 here:
http://www.capedory.org/board/viewtopic.php?t=25957
