Looking for starting crank
- SurryMark
- Location: Formerly CD27Y, Tula. Now Luders Sea Sprite 34
I hear the YSM8 is hard to crank start, but I'd like to have a crank on board. Anyone have one to sell?
- Alan Holman
- Location: As of 10/11/09 the proud new owner of Solo Noi(renaming scheduled for summer 2010)
Crank
"I'd like to have a crank on board. Anyone have one"
You really should think about this. A mellow fellow who knows where the beer is would be much more useful and pleasant.
The Meddler
(sorry about that, I couldn't resist)
The Meddler
Sometimes your vessel's becalmed for days and weeks on end,
Sometimes the winds of life will blow you off your course, my friend,
But the wind is sure to veer, you must stay aboard and steer,
And long may your big jib draw!
Hard to crank? I had a 1GM with a bum alternator. We crank started it all of the time. Just make sure to pull the decompression lever on the top of the engine, get the flywheel spinning and then ease off on the decompression lever. You do need to be careful not to allow water to come in and sit on top of the cylinder head. We worked it out and it wasn't a problem. In the long run, a solar panel worked best. This was all on a CD27 (1GM was underpowered for this boat). We never had any problems with the 25D that we had.
Bob B.
Bob B.
- SurryMark
Hmm. I don't understand the point about water on the cylinder head. Can you describe, where it came from, how you worked it out? And you're right about the ooph of an 8hp on a 27. It's got a whole lot more with a good breeze.Bob B wrote: You do need to be careful not to allow water to come in and sit on top of the cylinder head. We worked it out and it wasn't a problem. In the long run, a solar panel worked best.
Bob B.
When we would crankstart, our engine usually turned over pretty quick but if it didn't and you had to crank a while, the water pump was bringing water into the system. With the mixing elbow, water sometimes came back onto the cylinder from the mixing elbow. If allowed to sit on this, it could cause a problem. We ened up blowing a head gasket and it was a major problem. The mechanic that worked on it said that the water may have contributed to it.
We actually would keep the water intake seacock turned off until the engine fired and this prevented any possibility of water getting places where it doesn't belong. You have to be quick with turning it on as soon as it starts firing. We didn't have any problems after this.
The solar panel helped also.
- SurryMark
reply to bob
Good explanation. Perhaps it would be a good post on the main cape dory discussions, where more peope would see it.
I'd still like to find a crank, if anybody has one (why would they, though?). Also like to know how big a solar panel do you use, what brand, and where is it mounted?
Solar Panel
Mark,
We just had a 25 watt panel mounted on a homemade bracket on the stern. We could tilt it as the sun rose through the day. It did a pretty good job of keeping the batteries topped off while we were away. We were also very conservative with the use of electricity. We couldn't operate refrigeration unless we were on shore power and our autopilot would sap a battery in about a day if it was really working hard. With dual deep cycles we never had a problem. You might want to go with a higher wattage if you anticipate more drain on your batteries.
I posted our conversation on the discussion board. Thanks for the suggestion.
I hope you find your handle. I think it is a necessity for our small diesels to have one on hand.
Happy sailing.
Bob B.
CD Typhoon Liberty
Lancaster, SC
Happy sailing.
Bob B.
CD Typhoon Liberty
Lancaster, SC
Maybe Torresen Marine?
Hi MarkSurryMark wrote:I'd still like to find a crank, if anybody has one
I'd like to have one, too, and I think that Torresen Marine may have them.
Here's a LINK to a search I did there, but the descriptions are just a title, a parts number, and a price. I guess it would take a call or an email to see which one goes with which engine.
By the way, I noticed you refer to your "Y' engine as an "8 hp". Yanmar is misleading this way, since they use the peak, one-hour rating. I have a YSE8 (or YSM8, I forget), and the continuous hp rating is actually 7. I think the continuous rating is a more useful number, unless you're planning on some neck-snapping full-throttle acceleration
If you id the part number, and they have it, can you please advise? Thanks!
Santa Cruz, Monterey Bay CA
Crank handle search
I too have a 1GM, inmy 25D,and would be very happy to have a crank on board, particularly now that proper hand starting has been so clearly explained. Pls let us know if a source is found.
Thanks!!
Thanks!!
- SurryMark
crank supply, maybe
www.torresen.com lists a "universal" starting crank. I just wrote them for the second time asking what engines it fits. Will post the answer if I hear back.
260461 - Universal RIVET, STARTING CRANK HANDLE
Cirmarine lists the same crank, but has none in stock.
http://www.clrmarine.com/m4_view_item.h ... UJHW260461
Reid Supply lists a lot of cranks at
http://www.reidsupply.com/Results.aspx? ... 5Qod6U17og
Just ordered it from Torresen
I called Torresen, and they have the YSE8/YSB8 starting handle.
I've ordered it: The part number is 104211-76790, the price is $31.67, and they are charging $7.49 shipping to my son's address in Boston.
