where can I find a portable gas tank for the CD 22?
oatmealraisin
Post by oatmealraisin »
I have been searching for a gas tank to fit in my CD 22 and and having difficulty finding one. Does anyone know where I might acquire such a tank?
mgphl52
Post by mgphl52 »
If 3 gallons will do, you might try Go 2 Marine.
-michael
sfreihofer
Post by sfreihofer »
I can't speak to the CD22, but from my measurements, BRP Evinrude Johnson Part Number # 177001: UNIVERSAL Duratank 6 Gallon Fuel Tank will fit the CD25, with very little room to spare. You'll have to measure to see if they'll fit your boat. The following is the correspondence with evinrudeparts@yahoo.com which gives the dimensions of the tank.
Stan Freihofer
1981 CD25 #794
Ft. Lauderdale, FL
www.ReefRoof.com
SNIP>>
6.50lbs / 18.50in length X 11.50in width X 11.50in height
have them in stock please call
internet price $33.99 each
plus shipping
Website: Outboard Wizard Evinrude Parts
Parts Order/Request: Click Here Or Call (631) 991-4491
Technical Help Member Plans: Details/Join
--- On Sat, 8/29/09, Sfreihofer@aol.com <Sfreihofer@aol.com> wrote:
Subject: Fuel Tanks
To: evinrudeparts@yahoo.com
Date: Saturday, August 29, 2009, 7:45 PM
Help!
I need to know the dimensions and availability of the BRP Evinrude Johnson Part Number # 177001: UNIVERSAL Duratank 6 Gallon Fuel Tank. I need the dimensions to determine if these tanks will fit in the space available. I will need 2 tanks.
Thanks.
Stan Freihofer
SFreihofer@aol.com
<<SNIP
Instant Bubble-head. Just add water.
shavdog
3gallon tank
Post by shavdog »
you should do a search for my posts..... shavdog....i spent five hours on the internet searching for one that fits...i identified the make and model number in my post for your help...craig
hughesw
CD-22 Fuel Tank
Post by hughesw »
I use a 3 gal fuel tank that I bought a the local from Bass Pro Shops. The manufacturer is Moeller-Scepter-Neptune; manufacturer's part number is 04158. Measurements are 16.76" L X 10.75" W X 8.00" H, and it fits in the locker without modification. (Maximum height inside the locker is about 8 1/4".)
Bass Pro Shops Item Number: 38-580-664-00, and sells for $22.99
It looks to be the same fuel tank that Michael mentioned from Go 2 Marine, but the manufactuer part number is different and the height of that tank is listed as 9.87".
Hope this helps,
Warren
mgphl52
Post by mgphl52 »
Good spot, Warren!
Bass Pro actually has several Moeller tanks, including the one Go2 sells and they sell it for less. The "econo" tank does not have a fuel level gauge, but at only 3 gallons, that should be easy to tell by lifting the tank.
Bass Pro Fuel tanks.
-michael
Gary M
1982 CD22
Marina del Rey, CA
I was looking for a tank a while back
Post by Gary M »
http://www.capedory.org/board/viewtopic ... highlight=
Scroll down to the end of the thread to find my final solution.
Gary
