Gel coat question
Gel coat question
What color tint or tints would one use to go from white to Cape Dory hull offwhite? Black? I need to fill a small gouge before relaunch post Ike and have never worked with gel coat before. Thank you and Cheers. Charlie
- tartansailor
Color Matching
This can be made as easy or as difficult as you want it to be.
Forget an "exact!" match even if you had the original formula.
Start with:
black only
black and yellow
black, yellow, and red
PM me your results.
Naturally you will be doing this off the boat.
Start with:
black only
black and yellow
PM me your results.
- David van den Burgh
