Hello:
We have a 1986 CD36 with a varnished interior. The interior wood work is showing signs of wear and really should be refinished, however, we can't afford the ridiculous cost of having it done right now and we can't do it ourselves.
Questions:
1) What can we use to clean (such a mildew) and preserve the wood and its finish without adding a coating of something that will just complicate the proper refinishing when it is finally done?
2) Do most people refinish interiors with varnish or polyurethane?
3) What kind of wood is on the surface the interior plywood panelling?
I thank you in advance for your input.
Philip & Sharon
Interior Wood Maintenance
- Evergreen
- Location: 1986 Cape Dory 36 - Hull # 139 - "Evergreen" - kept at Great Island Boat Yard - Maine
Philip & Sharon
Re: Interior Wood Maintenance
Having looked at your CD36 when I was shopping for mine, I can tell you that your interior is in far far better condition then most out there!Evergreen wrote:Hello:
Questions:
Philip & Sharon
For basicly cleanup, such a mold and mildew that finds its way into the wood grain, I use a 50% water 50% white vinigar solution, it works well and doesnt hurt the finish.
I have slowly been refinishing my interior, which in most places just involves a light sanding and a fresh coat, some areas have needed stripping though, such as around the hatches. I have been using epiphanes rubbed effect varnish. Its a tad more glossy then whatever CD used origonally, but I am pleased with the results.
The veneer on the plywood is teak. Other parts of your boat have ash, but thats solid, not veneer.
Russell
Be very, very careful with furniture polish
Be very, very careful with furniture polish as much of this crap contains SILICONE! You DO NOT want to use ANY product containing ANY amount of silicone what so ever and LOTS of makers of furniture oils & polishes add silicone because it's cheap and puts a nice fake shine on.
The problem with silicone is in the future. If you use silicone now on a oiled interior finish, of which many CD's are, you've basically ruined any future chances of upgrading to a varnish or polyurethane finish in the future because NOTHING will stick to silicone!
If your interior has mold in the wood grain it's most likely an oiled finish and not a varnish. To keep up with an oiled interior I really like Weiman's Lemon Oil. Weiman's is the only lemon oil I've found that contains NO SILICONE and actually states it right on the bottle!
Believe it or not the Mr. Clean Magic Eraser and regular H20 do a great job at cleaning mold from dirty interior oiled teak and with no chemicals!
Weiman's Lemon Oil: http://www.weiman.com/products/furnitur ... screen.php
