What's this Material!
Lew Gresham
Post by Lew Gresham »
Anyone know what this material is the cleats are made of, and the base they are attached. This is original hardware for my 74 Ty.
http://i125.photobucket.com/albums/p52/ ... terial.jpg
Oswego John
What's This Material
Post by Oswego John »
Can't say for sure. My guess is that the hardware is Everdur or some type of silicon bronze.
The side grain of the base looks to me like stained oak, probably white oak.
And then again, after closer scrutiny, it might turn out to be teak or mahogany. If, as you say, it is original, Cape Dory used a lot of teak as bases for cleats, etc.
As for the cams, my guess, and it's just a guess, is that they are man made from some cambric based and/or phenolic compound formed under high pressure in molds. I lean more toward cambric and less to phenolic content.
Just my 2¢
Lew Gresham
Material!
Sorry if my post message was not clear enough, the base is teak I know, but I was talking about the base the cleats are fastened to. I have seen this stuff around before but not sure what it's called.
Thanks again!
Weekender
hull #914
henry hey
Location: Former owner: CD25 - 'Homeward Bound' hull #711. Now sailing with C. Brey aboard Sabre 28 Delphine
This Brown Material -- (old hardware)
Post by henry hey »
Hi Lew,
That material is Tufnol. I used to have some tufnol cam cleats on my 1967 O'day Mariner. It's actually pretty solid stuff and if it is working well I wouldn't replace it. My cam cleats eventually just wore down to the point where they wouldn't hold lines anymore and had to be replaced.
Tufnol was pretty common in the 60's and early 70's for a lot of smaller sailboat hardware.
There are still a few places that sell tufnol hardware:
http://marinestore.co.uk/page/mrst/CTGY ... camcleats/
Some more info on tufnol (in it's current form)
http://www.bayplastics.co.uk/suppliers/ ... intro).htm
I believe that tufnol is (at least now) made by http://www.tufnol.com
-henry
Lew Gresham
Material!
Now Henry, that's what I call a great post! Thanks! The picture I posted is before I cleaned the unit up. It now looks brand new. I sanded down the flaked chrome ring that holds the sheet line in place. It's brass and cleaned up nicely. This stuff looks somewhat like a formica product. Anyway Henry, thanks again for the sites!
The above site will be saved should I ever need to replace.
Weekender
hull #914
Will Wheatley
On Mill Creek in Annnapolis, MD
Post by Will Wheatley »
Hi Lew
I have four winches on my CD25 made of the same material as well as two blocks the I bought at a used part place. They were made by a company from England that is no longer around. I always thought they just spelled their name funny for kicks but now I see there was a reason. The company name was TUFFITTINGS.
Happy Sailoring~~~~/)~~~~
Will Wheatley, CDSOA
Sailing The Bay near Chesapeake Beach, MD
