Cockpit drains on a CD25
carldoc
Post by carldoc »
With all this rain in the Northeast, the last thing I need is a flooded cockpit. Both drains are clogged. I've tried coat hangers and we are going to try an electric snake line. Any other ideas and has this happened to anyone else?
tartansailor
A Garden Hose
Post by tartansailor »
If you can get to a dock with a water hose to jam into the drain, that would do it; as it has done for me.
As a temporary fix till I substantially enlarge mine, I've replaced the 90° elbows with pairs of 45s and thus far they have not plugged.
Viam Inveniam Aut Faciam
Carl Thunberg
Try a sink plunger.
Post by Carl Thunberg »
My cockpit drains plug all the time with various stuff. Before you do anything drastic like use an electric snake, try a regular sink plunger (not a toilet plunger). It works for me every time. Actually I got that tip here on the Board. I don't remember who said it first, but it's probably the one tip I've gotten the most use out of.
Carl
Sir Isaac Newton
carldoc
Post by carldoc »
Thanks guys. I did a search and received some great research. I'll get a sink plunger today.
If you get confused just listen to the music play.
Plung and dive
Yep a little sink plunger is standard equipment on our boats. Even it that works for now plan on diving down during the summer with a screwdriver or something similar and route out the marine creatures that might find your through hull fittings a fine place to make a home. I do the seacocks and the engine intake strainer every so often durring the season. The plunger will not flush out a barnacles or mussels if they are growing there. We are blessed with lots of dog hair in our cockpit drains, Steve.
mahalocd36
mechanical fingers
Post by mahalocd36 »
When the sink plunger didn't work for us, we used mechanical fingers to reach down there and get the junk out. It's always amazing how out on a mooring they can get clogged, but yup, we've got a dog on board. Mechanical fingers are another useful tool to have aboard to find stuff that drops in the bilge or whereever just out of reach.
Melissa Abato
www.sailmahalo.com
