Mast Pin
Lois Flanagan
Mast Pin
Post by Lois Flanagan »
I lost one of the mast pins when stepping the mast this fall. It is 4 7/8 inches long and 7/16 inches in diameter. One end is tapered, to go through the mast holes. There are holes in each end to put a cotter pin in. Any ideas on where I might find one? Thanx
loisflanagan@alltel.net
Dave Olson
Re: Mast Pin
Post by Dave Olson »
-RigRite is the original manufacturer 401-739-1140 Dave
Lois Flanagan wrote: I lost one of the mast pins when stepping the mast this fall. It is 4 7/8 inches long and 7/16 inches in diameter. One end is tapered, to go through the mast holes. There are holes in each end to put a cotter pin in. Any ideas on where I might find one? Thanx
Dave_Olson@Starkey.com
