Typhoon Weekender Rollerfurl
George Loesel
Post by George Loesel »
I am contemplating installing a rollerfurl on my weekender.
Question 1. Should I use my existing genoa and have it recut to use on the furler or should I take the opportunity to get an even larger genoa cut.
Question 2....The other day I was following a Pierson Ensign, a 23 or 24 ft boat and he could point 5 to 10 degrees higher than I could into the wind.....any tips for me on how to tune the rigging in order to eek out a few more degrees of pointing?????
Thanks in advance.....George
gloesel@concentric.net
mark kotapka
Re: Typhoon Weekender Rollerfurl
Post by mark kotapka »
George Loesel wrote: I know a friend who installed a rollerfurler from Cruising Designs Inc.(model 2?). She had her existing genoa cut and it seems to work fine.
George Loesel wrote: Question 1. Should I use my existing genoa and have it recut to use on the furler or should I take the opportunity to get an even larger genoa cut.
makota@pahosp.com
Ron Fitzpatrick
Post by Ron Fitzpatrick »
George,
I have a CDI FlexFurling system on my Typhoon Weekender. My old genoa was pretty tired, so I had a new one made which has a foam insert sewn into the luff. The foam is intended to give the sail something to wrap around when I shorten the jib to about the size of a working jib or storm jib. The system works well, especially since I do a lot of single-handed sailing. But, when the wind pipes up and you shorten the jib, you're gonna fall even farther behind that Pearson/Ensign with a furling jib, because of the sheet block location for the furling system. If you were changing to a smaller "hanked-on" jib, you could run the sheets to a block on the cabin roof and haul the jib closer to the center of the boat, which allows you to point a bit higher. I suspect that you could rig some type of snatch block to grab the jib sheets and bring them closer to center, but I still doubt that you'll catch that Pearson. I think he's got a fin keel, which is almost always quicker and points higher than the Typhoon's full keel.
Good Luck
rjfitz@worldpath.net
Harris
Pearson ensign...Full keel!
Post by Harris »
Just a finer entry and longer waterline.
Ron Fitzpatrick wrote: George,
Good Luck
hg@myhost.com
Jon Larson
Re: Pearson ensign...Full keel!
Post by Jon Larson »
Indeed, is not the Pearson Ensign yet another design from our beloved Carl Alberg??
Jon Larson
Cape Dory 30 PERI
San Francisco Bay
Harris wrote: Just a finer entry and longer waterline.
Good Luck
jon9@ix.netcom.com
Ron Fitzpatrick
Jon Larson wrote: Indeed, is not the Pearson Ensign yet another design from our beloved Carl Alberg??
Well then, perhaps there's a chance for you to catch that Ensign after all. But, you'll still have to bring that jib sheet in close.
Thanks for the corrections.
Ron Fitzpatrick
Typhoon Weekender
Plumb Krazy (#48)
