Thanks for taking the time to post, John. It's a very interesting project, requiring a lot of fore thought. - Jean
Hi Fred. No plans for a PSS. While I have met some people happy with the PSS I have run across too many that had trouble with them. The biggest issue for me is expense and you can’t repair them in the water. And foe the type of sailing I do I think there is too much risk and potential for hassle. So, I opted for the a simple tried and true bronze stuffing box. Because the shaft log exits above the narrow spot in 5 back of the keel on sock CDs I should have easy access. I’m thinking of packing it with GFO packing material. Though I have no experience with GFO, what I have read is very good. Installed correctly (same as regular packing) it is virtually dripless. But, I’ll also build a water drip tray and divert any drips it into a container.fmueller wrote:Nice work John ...
Will you be fitting a PSS shaft seal ? We did on Jerezana, as well as plumbing the hose barb from the cooling water circuit.
Where will the set screws for the cutlass bearing go ?
It will be interesting to see the steering dynamics in reverse (I know that is not your primary motivation) because there will be "some" prop wash in reverse over the very top portion of your rudder ...
thanks for your posts as always
Fred
http://gfopacking.com/
Two set screws will be installed in the G10 tube.
I have no idea about handling under power. I’m sure it will be compromised vs a conventional arrangement. It'll be a learning experience.
Thanks Jim. I’m confident about my ability to do a respectable job but still a little anxious about if it was the right thing to do. The whole thing seems like such a big complication to what was for four years a wonderfully simple boat. Having said that, I definitely thought about it long enough and so I am fully committed. Once I have it completed I’ll probably be thinking “why did I wait so long!”Jim Walsh wrote:Very impressed with the planning and execution so far. Looks rock solid and to your usual high standards.
It’s a lot more difficult doing a project like this with the boat 35 miles from our home (vice the 35 feet when she was in the boat shed) but I am actually enjoying the work and all the challenges it entails....
Thanks Jean.Frenchy wrote:Thanks for taking the time to post, John. It's a very interesting project, requiring a lot of fore thought. - Jean
- John Danicic
John:John Stone WroteI’m thinking of packing it with GFO packing material. Though I have no experience with GFO, what I have read is very good. Installed correctly (same as regular packing) it is virtually dripless. But, I’ll also build a water drip tray and divert any drips it into a container.
Glad you decided to tackle the project as well as documenting it for us. Very interesting.
As a user of the GFO packing material for the last 12 years or so I can attest to its qualities. It doesn't leak much at all and the one time it did, a simple tightening of the packing nut was all it took to stop it. I replaced it only twice in all those years and only because of the guilt of not paying attention to it. I found the old stuff almost new in both cases. I average about 100 hours on the engine (original Perkins 4-108) a season.
Sail on
John Danicic
CD36 - Mariah- #124
Lake Superior- The Apostle Islands
CDSOA #655
Cape Dory Picture Posts
John Danicic
CD36 - Mariah- #124
CDSOA #655
That’s good to know John D. Thanks.John Danicic wrote:John:John Stone WroteI’m thinking of packing it with GFO packing material. Though I have no experience with GFO, what I have read is very good. Installed correctly (same as regular packing) it is virtually dripless. But, I’ll also build a water drip tray and divert any drips it into a container.
More progress today. Pulled the peel ply. Looks pretty good. Then after I took the pictures posted below I added two more layers of biaxial, this time under the skeg and wrapped them up around each side.
For the last two layers I used lighter 10oz biaxial because of the tight turn at the corners under the skeg. I also added another layer of 1708 on the shaft log inside the boat where it emerges into the engine compartment. I covered all the work today with peel ply release fabric.
Next step is to start fairing and get as much done as I can before the temps drop. Then I’ll turn to fabricating and installing the engine beds.
- 4F58F3F0-995B-41A2-94BF-B639994BA933.jpeg (3.81 MiB) Viewed 1833 times
- 652A36A4-4CEB-41E3-863C-A834FF1F56B6.jpeg (3.71 MiB) Viewed 1833 times
- D2E65A03-C8C7-4924-9C08-DD99B0281540.jpeg (4.42 MiB) Viewed 1833 times
Steady progress. Got the first round of fairing applied yesterday. Sanded it today. With sanding complete I vacuumed and performed an acetone wipe down. Next, I added two layers of biaxial to the top of the rudder and covered it with peel-ply. Then, I troweled on the second layer of fairing compound.
About ready to start on the engine beds. Still need to decide which engine—the 20hp or 25 hp Beta.
- I washed the amine blush off the first coat of fairing compound then sanded with 80 grit to prep for the second round of fairing. It’s already starting to look a bit smoother.
- 7C3A8EBD-EA61-4835-B5A8-D192437EA851.jpeg (3.45 MiB) Viewed 1803 times
- Second layer of fairing compound added. Also applied two layers of biaxial to the top of the rudder.
- C952C9A4-B71C-44A4-A959-7C64410EB609.jpeg (3.72 MiB) Viewed 1803 times
- tjr818
John,
Great work as always, and thank you so much for posting the steps along the way. Your work is always interesting.
It is a bit off topic but one of your last photos shows what seems to be an interesting boat off to the port side of Far Reach. Can you tell us anything about your neighbor?
tjr818 wrote:John,
Which boat you asking about? The wood boat?
- tjr818
Yes, This one, it sure looks unusual:
wow John - looking great !
does not directly apply but you might find this interesting ...
https://www.offcenterharbor.com/videos/ ... ment-11899
Fred
Fred
Fred Mueller
Jerezana
CD 27 Narragansett Bay
Jerezana
Hi Fred, thanks for the link. I’ll take a look at it. I’m a life member of Off Center Harbor. It’s a great site.fmueller wrote:wow John - looking great !
Fred
Hi Timtjr818 wrote:Yes, This one, it sure looks unusual:
That is a 60’ Trumpy motor yacht. A 1961 I believe. She’s mahogany on oak. Pretty cool boat. She is a bit down on her luck I think. I am told she is deserving of a complete restoration which she is not getting. Takes deep pockets to care for a boat like that. I’m partial to the pre WWII Trumpys. But you have to be very wealthy to own a boat like that and keep up with her maintenance.
- 007BBC38-80CC-4B1A-BB7E-0BD130D7CA11.jpeg (3.84 MiB) Viewed 1778 times
- tjr818
Thanks John,
Maybe your level of craftsmanship will shame the owner into investing a few more dollars. I have owned too many wooden boats. I think fiberglass is the way to go, especially for common folk like me.
tjr818 wrote:Thanks John,
I appreciate the kind words....I’m humbled.
We are in a small sub contracted boat yard inside of a large marine industrial complex. In an nearby boatyard inside this complex are two cool boats (pictures below) 75’ from one another. The Trumpy is a 1947. I think it’s the one previously owned by Greta Van Susteren and her husband. She is having a lot of work done (the Trumpy, not Greta
- A 1947 Trumpy.
- 070B0FFD-24C5-472D-B257-94E88F0E535D.jpeg (4.33 MiB) Viewed 1773 times
- Cochise, the Dashew’s 78’ FPB.
- 872F68ED-2A97-4E82-8F53-2B8AC773550E.jpeg (2.93 MiB) Viewed 1773 times
Those are some pretty cool boats and the Trumpy is very pretty.
