Tim:
Thanks VERY much for the additional photos. I am not sure you realize how helpful your photos are to a dummy like me.
In looking at the two (2) line deck organizer from Spinlock it looks from your photos that it is "angled" and NOT squared up with the hatch, rail, etc. You wrote: "
I played with the idea of angling the halyard to decrease the angle and load on the deck organizer, but it really didn't make much difference and it just did not look right to my eye,, so the halyard will be parallel with the hatch opening and the handrail".
From all the photos I have seen of a deck organizer they are sort of at a 45 degree angle and are not parallel (or squared up). Check out photos posted by Warren Kaplan on S/V Sine Qua Non (a CD 27). I think this is because, as you stated, angling the deck organizer puts less pressure (stress) on the line and the deck organizer wheels. Perhaps reconsider
From what I have seen on local sailboats and from photos on this website, the "angled" deck organizer looks good. But, to each his own. I personally prefer brunettes but I do understand the appeal of redheads and blondes.
I think I am going to purchase a three (3) line clutch and three (3) line deck organizer. I am hoping to be able to route the two (2) reefing lines back through the line clutch and to the cockpit as well as the main halyard. I am not sure if the line clutch will be able to "grab" the smaller diameter reefing lines; smaller diameter as compared with the main halyard. Something I will have to consider.
Tim and Mike:
Thanks for the suggestion about moving the mast. Yes, I had thought of that. My concern was that I thought I would be building a 2x4 bracket (
X) at both the bow and stern where the mast would rest while also resting on the cabin roof with the 2x4 bracket standing up in the cockpit sole. This is how the mast was initially stored when S/V Bali Ha'i was hauled and prepped for the NJ hurricane in 2011 (Irene
) It is my understanding the mast is very heavy and I did not want it supported by just the pushpit and/or pulpit.
It is a minor issue. As you both have suggested I can move it to one side for a couple hours while working in the cabin or I can build a different brace/bracket to take the weight of the mast. I had hoped to put the mast in the back patio but, again, I think it is too heavy to be moved without mechanical (forklift) help.
Once again, this board is outstanding
